First hurdle :
Took the C.H.I.P. out of the box and connected it to the USB port on my computer and waited for the magic to happen. As one might expect, it didn’t ![]()
Under windows 10 the driver required to access the C.H.I.P. is not readily available. The device will show up as a “CDC Gadget” with a yellow warning indicator in your device manager.
The solution :
https://dl.dropboxusercontent.com/u/10951211/Screenshots/ShareX/Desktop/2016/02/piusbser.inf_amd64_55a2ec0249c26a21.zip
This link will lead you to a working driver that you can install , after which the C.H.I.P. will appear as " PI USB to Serial (COMx)" in your Device manager.
From there it’s a matter of firing up Putty and attaching to the indicated COM port. In my case it was COM5.
Details : https://bbs.nextthing.co/t/need-gadget-serial-v2-4-driver-for-windows-7/2044/5
Onward! Onward!
- D
