nothing really to do with Outernet… But it is a Cool SDR internet site Live…
something new i came across
Can also check out http://sdr.hu/
If you got OpenWebRX running on Armbian, I don’t see why you couldn’t use the Dreamcatcher to serve this up, just need the appropriate antenna, CPU might be a constraint though. I’m working on an HF setup with a Wellbrook mag loop now that I’ll be putting up on one of these sites as well. Might also be interested in the KiwiSDR, its an HF receiver with enough bandwidth to see the entire 0-30mhz at the same time, if your CPU can keep up. ![]()
