I Had a good working receiver on arch until a power failure killed the software.
Building a new is giving problems. I still have good reception (1,2 mtr dish), good indications on the TVheadend but no data. Looking at ondd it reports /usr/lib/libcrypto.so.1.0.0: no version information available (required by ondd). Looking at journal it reports “continuity error: X =>Y” and also “section error: bad crc” very often. Any Ideas?
As far as I know, that’s normal.
If you are getting a lot of these, and I mean like 10 in a row, etc, that normally means a poor SNR.
I’ll see what this is about. It doesn’t seem like it does anything, though.
I confirm that there’s an issue with libcrypto and ondd. You’ll usually see something like this in ondd logs if you have this issue:
Dec 19 12:46:51 outernet ipd[809]: decrypted crc failed
Dec 19 12:46:53 outernet ipd[809]: decrypted crc failed
Dec 19 12:46:55 outernet ipd[809]: decrypted crc failed
Dec 19 12:46:57 outernet ipd[809]: decrypted crc failed
New version of ondd will be released soonish.
