Could someone shed some light on the two SMA connections of the Dreamcatcher 2301 board? Specifically, can one of them be used for an external wifi antenna? I’ve not been able to sort that from the forum or Quickstart guides or by looking at my board. Thanks, Mark.
Bump to @Syed
@Root944 Those are for factory testing. They are not wifi antennas. The wifi antenna is integrated into the large module on the board.
Thank you for the quick answer Syed. I did see the internal antenna trace. Best, Mark.
The schematic is posted on Github, so if you can figure out how to make it useful, then go nuts!
