[236733.369743@1] normal card in
[236733.870377@0] sd: mmc_rescan_try_freq: trying to init card at 400000 Hz
[236734.172229@1] sd: new high speed SDXC card at address e624, clock 50000000, 4-bit-bus-width
[236734.175539@1] mmcblk0: sd:e624 SU64G 59.4 GiB
[236734.184256@1] mmcblk0: p1
[236734.799878@1] EXT4-fs error (device mmcblk0p1): ext4_find_entry:1309: inode #2: comm hotplug.storage: reading directory lblock 0
[236737.821050@1] EXT4-fs error (device mmcblk0p1): ext4_find_entry:1309: inode #2: comm hotplug.storage: reading directory lblock 0
[236738.275028@1] wetek-dvb dvb.8: stop_feed_dmx0
[236738.275051@1] wetek-dvb dvb.8: FLUSH FIFO0
[236738.275061@1] wetek-dvb dvb.8: FLUSH ok
[236741.251496@1] EXT4-fs error (device mmcblk0p1): ext4_read_inode_bitmap:175: comm hotplug.storage: Cannot read inode bitmap - block_group = 0, inode_bitmap = 1026
[236741.612369@0] wetek-dvb dvb.8: start_feed_dmx0
[236741.612401@0] wetek-dvb dvb.8: FLUSH FIFO0
[236741.612410@0] wetek-dvb dvb.8: FLUSH ok
[236741.612420@0] wetek-dvb dvb.8: FIFO0<->0
[236741.613438@0] i2c i2c-1: avl6211_set_frontend: delivery_system=5 frequency=1489000 symbol_rate=11719000
[236741.620794@0] Buffer I/O error on device mmcblk0p1, logical block 7635458
[236741.620810@0] lost page write due to I/O error on mmcblk0p1
[236741.620838@0] JBD2: Error -5 detected when updating journal superblock for mmcblk0p1-8.
[236741.670117@0] i2c i2c-1: BF is 64,BW is 10688
[236742.150274@0] i2c i2c-1: Tuner successfully lock!
[236742.310389@0] i2c i2c-1: Service locked!!!
[236915.775934@1] i2c i2c-1: avl6211_set_frontend: delivery_system=5 frequency=1489000 symbol_rate=11719000
[236915.834445@1] i2c i2c-1: BF is 64,BW is 10688
[236916.334250@1] i2c i2c-1: Tuner successfully lock!
[236916.494419@1] i2c i2c-1: Service locked!!!
and just put the old card …
[ 446.888590@0] Buffer I/O error on device mmcblk0p1, logical block 492603
[ 446.888596@0] Buffer I/O error on device mmcblk0p1, logical block 492604
[ 446.888602@0] Buffer I/O error on device mmcblk0p1, logical block 492605
[ 446.888609@0] Buffer I/O error on device mmcblk0p1, logical block 492606
[ 446.888615@0] Buffer I/O error on device mmcblk0p1, logical block 492607
[ 446.888624@0] EXT4-fs warning (device mmcblk0p1): ext4_end_bio:286: I/O error writing to inode 131108 (offset 12713984 size 135168 starting block 492832)
[ 446.888641@0] Buffer I/O error on device mmcblk0p1, logical block 492608
[ 446.888649@0] Buffer I/O error on device mmcblk0p1, logical block 492609
[ 446.888656@0] Buffer I/O error on device mmcblk0p1, logical block 492610
[ 446.888663@0] Buffer I/O error on device mmcblk0p1, logical block 492611
[ 446.888669@0] Buffer I/O error on device mmcblk0p1, logical block 492612
[ 446.888676@0] Buffer I/O error on device mmcblk0p1, logical block 492613
[ 446.888682@0] Buffer I/O error on device mmcblk0p1, logical block 492614
[ 446.888691@0] EXT4-fs warning (device mmcblk0p1): ext4_end_bio:286: I/O error writing to inode 131108 (offset 12845056 size 28672 starting block 492864)
[ 446.888726@0] EXT4-fs (mmcblk0p1): ext4_da_writepages: jbd2_start: 2147480504 pages, ino 131108; err -30
[ 446.895798@0] Buffer I/O error on device mmcblk0p1, logical block 524289
[ 446.895807@0] lost page write due to I/O error on mmcblk0p1
[ 447.138589@1] sd: mmc_rescan_try_freq: trying to init card at 400000 Hz
[ 447.312041@1] sd: SD Status: Invalid Allocation Unit size.
[ 447.315548@1] sd: new high speed SDXC card at address 0001, clock 50000000, 4-bit-bus-width
[ 447.316795@1] mmcblk0: sd:0001 00000 58.5 GiB
[ 447.321795@1] mmcblk0: p1
[ 447.604254@1] wetek-dvb dvb.8: stop_feed_dmx0
[ 447.604278@1] wetek-dvb dvb.8: FLUSH FIFO0
[ 447.604286@1] wetek-dvb dvb.8: FLUSH ok
[ 447.674767@1] EXT4-fs error (device mmcblk0p1): ext4_find_entry:1309: inode #2: comm hotplug.storage: reading directory lblock 0
[ 450.701076@1] EXT4-fs error (device mmcblk0p1): ext4_find_entry:1309: inode #2: comm hotplug.storage: reading directory lblock 0
[ 450.888403@0] i2c i2c-1: avl6211_set_frontend: delivery_system=5 frequency=1489000 symbol_rate=11719000
[ 450.889122@1] wetek-dvb dvb.8: start_feed_dmx0
[ 450.889128@1] wetek-dvb dvb.8: FLUSH FIFO0
[ 450.889134@1] wetek-dvb dvb.8: FLUSH ok
[ 450.889138@1] wetek-dvb dvb.8: FIFO0<->0
[ 450.888695@0] EXT4-fs error (device mmcblk0p1): ext4_put_super:760: Couldn’t clean up the journal
[ 450.947095@0] i2c i2c-1: BF is 64,BW is 10688
[ 451.447254@0] i2c i2c-1: Tuner successfully lock!
[ 451.607349@0] i2c i2c-1: Service locked!!!
[ 465.459362@1] force enable DISCARD here for ext4 fs
[ 465.459384@1] EXT4-fs (mmcblk0p1): mounting ext3 file system using the ext4 subsystem
[ 465.528563@1] checked enable EXT4 DISCARD here
[ 465.528582@1] EXT4-fs (mmcblk0p1): mounting with “discard” option, but the device does not support discard
[ 465.528591@1] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
