There are some questions i have about how the service will work once it is ready.
- What software/device will i need to use to connect a device?
- How exactly is this going to show on my smarthphone or computer? I will see something like “global wifi is available”?
- Will i be able to access to any content i can access now using my normal connection? P2P included?
a. What would i need to do if i want to publish a website and make it available on the outernet? - Is there any restriction on air space usage? Or laws stops applying at the height you plan to launch the satellites?
- If i connect to the outernet I need to disable my connection to my carrier? Or can they work at the same time?
