Trying to get Outernet to run on a Raspberry Pi 3 under Raspbian. I’m a Noobie.
During the upgrade to “Jessie testing” (to be able to use Librarian), everything goes fine until the end. The last line in the terminal shows that “PostgreSQL” is not configured. Is this meaningful?
The demodulator appears to run fine.
However, when trying to run the decoder, an unable to load config error is encountered
Also, an command not found error is encountered when starting the indexer.
Lastly, when trying to start Librarian there is another command not found error.
So has there been any progress on being able to use this with Raspbian on a RPi3? I tried to follow the instructions in document Outernet L-Band on Raspbian which after a while looked like it was working but never received any packets. Just to see if it would help I started over with using the rxos image instead. It worked great with that. Starting seeing packets right away. But I would rather have Raspbian to work if possible, but I am still a novice as far as Raspbian after about 2 years. Slowly learning more and more.
