I downloaded Skylark v5.8 and flashed it to an sd card with etcher. But when it’s finished, it always show me “flash failed”. I try to redownload Skylark, but same problem.
So i try to boot my DreamCatcher with the sd card anyway, but I can’t see the wifi from the DreamCatcher but I don’t understand what is the problem…
If anyone can help me or send me an older version of Skylark to test, it would be very nice and very appreciated
I’m mentioning this only because many of us experienced it with our first Dreamcatchers a few years ago.
If you are using a “normal” USB charging cable, see if you can find a cable with heavier wire inside (sometimes called a “charging/data” cable). We found that a Raspberry Pi power supply and cable will work, where a “normal” phone charging cable would not allow enough current to pass to fully power the Dreamcatcher. Just a suggestion.
