1-sd card 8 Gb format fat32 volume label ext_store OK
2-I inserted a new SD Card
3-initial configuration OK
4-RECEIVING CONTENT OK
5-100 updates available
add all to library
0 update
add to library
0 update
where am I wrong?
perhaps permission problems on the new sd card?
Could you post the application log? You can find it under Settings.
http://stazioni.atwebpages.com/log.txt
http://stazioni.atwebpages.com/syslog_0.4.post5_2015-10-19_17-19-20
This is the same problem I reported awhile ago trying to use a hard drive on ORxPi v0.2.8. Ken
I also tested it with a 40 GB harddrive.
Sorry for not responding in a timely fashion. It’s a bit hectic over here. Do you know how to handle Linux command line and SSH?
little, but I’m not expert
how can I fix the sd card/hardisk
I am seeing same issue with usb jump drive and lighthouse.
Also, 32gb drive is only seen as 16gb.
A post was split to a new topic: No new content notification
If you could log into your box (username/pass: outernet/outernet) and give me the output of:
mount
ls -la /mnt
that would be helpful. We are trying to reproduce the issue, but currently unable to.
Could you please elaborate on the ‘same issue’ comment? What exactly is it that you are seeing? Also, I’ve moved your second post to a separate topic. Hope you don’t mind.
hd 160GB usb
outernet@outernet:~$ ls -la /mnt
total 32
drwxr-xr-x 1 root root 140 Oct 7 15:35 ./
drwxrwxrwt 1 root root 40 Oct 23 14:28 …/
drwxr-xr-x 5 root root 32768 Jan 1 1970 data/
drwxrwsr-x 2 root config 816 Oct 21 00:58 persist/
drwxr-xr-x 16 root root 1184 Oct 15 15:13 rootfs/
drwxrwxrwt 8 root root 160 Oct 23 14:28 tmpfs/
drwxrwxrwx 1 root root 80 Jan 1 2015 usb/
sd 8Gb
total 4
drwxr-xr-x 1 root root 120 Oct 7 15:35 ./
drwxrwxrwt 1 root root 40 Oct 23 14:42 …/
drwxr-xr-x 5 root root 4096 Jan 1 2015 data/
drwxrwxrwt 8 root root 160 Oct 23 14:42 tmpfs/
This is the internal sd
drwxrwxrwt 1 root root 40 Oct 23 17:56 …/
drwxrwsr-x 5 root data 368 Jan 1 2015 data/
drwxrwxrwt 8 root root 160 Oct 23 17:56 tmpfs/
you need to change
with this?
as you change this allowed?
I think this may be similar issue,
Lighthouse 1.4.0
I added usb memory
updates available
add all to library
0 update
add to library
0 update
Can not add items to library, library remains empty.
I do not see this issue with using only internal memory.
Now have lighthouse 1.4.1
Now no updates showing available
Library still empty
Hope this helps
No, it generally shold work as is.
Did you format your external drive before attaching or did you use an existing one?
As of 1.4.100 firmware, updates are no longer manually added to the library. Instead they are periodically scanned and added automatically. There is also a 1.4.201 image on air that will fix a few issues with 1.4.100.
I’ve formatted with gparted
Do you have another disk that you could try?
I I have many.
I try to change
