I would like to say I have great news, but you’ll have to settle for another alpha-quality release for testing purposes. This time, we have two Raspbian images using Linux v3.18.9+ kernel.
Please test-drive them and let us know if you run into issues.
LIbrarian v0.1b3
The third Librarian beta is the default on the images. I do not recommend upgrading to development version as it currently does not work on Pi.
Geniatech HDStar support
The Geniatech HDStar v3 is finally supported. It works on Linux v3.18.9+ so please hold the upgrades. Since we have not yet found a way to differentiate between v2 and v3, you are on your own purchasing the device.
The included kernel modules can be obtained separately on the ORx project page (see bottom of the page for details).
If there is sufficient interest, we may try to obtain them and sell them online as a PCB-only (no case) version for a bit less than what they are sold online, and guarantee support for it in future.
To identify the v3 device, you can look at the PCB. It should say SU3000 v3.0. Expected syslog output is this:
Mar 19 04:57:37 outernet kernel: [ 2569.840572] usb 1-1.2: new high-speed USB device number 6 using dwc_otg
Mar 19 04:57:37 outernet kernel: [ 2569.941989] usb 1-1.2: New USB device found, idVendor=1f4d, idProduct=3000
Mar 19 04:57:37 outernet kernel: [ 2569.942031] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Mar 19 04:57:37 outernet kernel: [ 2569.942054] usb 1-1.2: Product: USB Device
Mar 19 04:57:37 outernet kernel: [ 2569.942071] usb 1-1.2: Manufacturer: geniatech
Mar 19 04:57:37 outernet kernel: [ 2569.942088] usb 1-1.2: SerialNumber: 0002
Mar 19 04:57:37 outernet kernel: [ 2569.949581] dw2102: su3000_identify_state
Mar 19 04:57:37 outernet kernel: [ 2569.949621] dvb-usb: found a 'SU3000HD DVB-S USB2.0' in warm state.
Mar 19 04:57:37 outernet kernel: [ 2569.949652] dw2102: su3000_power_ctrl: 1, initialized 0
Mar 19 04:57:37 outernet kernel: [ 2569.950167] dvb-usb: will pass the complete MPEG2 transport stream to the software demuxer.
Mar 19 04:57:37 outernet kernel: [ 2569.953365] DVB: registering new adapter (SU3000HD DVB-S USB2.0)
Mar 19 04:57:37 outernet kernel: [ 2569.958917] dvb-usb: MAC address: 00:00:00:00:00:00
Mar 19 04:57:37 outernet kernel: [ 2570.271692] Invalid probe, probably not a DS3000
Mar 19 04:57:37 outernet kernel: [ 2570.271768] dvb-usb: no frontend was attached by 'SU3000HD DVB-S USB2.0'
Mar 19 04:57:37 outernet kernel: [ 2570.272167] Registered IR keymap rc-su3000
Mar 19 04:57:37 outernet kernel: [ 2570.272856] input: IR-receiver inside an USB DVB receiver as /devices/platform/bcm2708_usb/usb1/1-1/1-1.2/rc/rc0/input1
Mar 19 04:57:37 outernet kernel: [ 2570.273303] rc0: IR-receiver inside an USB DVB receiver as /devices/platform/bcm2708_usb/usb1/1-1/1-1.2/rc/rc0
Mar 19 04:57:37 outernet kernel: [ 2570.273337] dvb-usb: schedule remote query interval to 150 msecs.
Mar 19 04:57:37 outernet kernel: [ 2570.273366] dw2102: su3000_power_ctrl: 0, initialized 1
Mar 19 04:57:37 outernet kernel: [ 2570.273384] dvb-usb: SU3000HD DVB-S USB2.0 successfully initialized and connected.
Mar 19 04:57:39 outernet kernel: [ 2572.420516] dvb-usb: recv bulk message failed: -110
Mar 19 04:57:39 outernet kernel: [ 2572.420577] dw2102: i2c transfer failed.
PCTV 461e
PCTV is still supported. However, you may need to use a powered USB hub or a good power supply for Raspberry Pi. If your Pi goes into endless reboot loop, try plugging PCTV into a powered USB hub. Also, on my test device, it would cause all kinds of problems if I unplug or plug in the hub while the device is operational. The power supply that worked for me was one that came with a cheap HTC phone, which has 5V / 1A output.
Access-point support
AP is currently password-protected. Password is outernet. This will most likely change in future releases.
In the AP image, I’ve finally had the time to make WiFi support work. Unlike the previous releases, it is now possible to have both WiFi AP and connect to LAN via ethernet port.
Edimax (Realtek RTL8188CUS) dongle has been tested and works.
Realtek Wireless N dongle (tiny one, R8188EU) does not work (in general, not just as AP).
TP-Link TL-WN722N wireless dongle is not supported, but we may get it to work soon. At any rate, if you wish to plug it in, you may need a powered hub, just like with PCTV 461e.
