It works now. First time that I read nicely edited articles with pictures (UNHCR, Wikinews and Malawi)! Config: Geniatech, 80cm-dish, RPI1. Will report more tomorrow.
Good work, Branko!
Don’t think the WiFi and ethernet issues are relevent to Lighthouse Version 2.0.003, but they are working fine on my Lighthouse connected thru Galaxy 19. Ken
Yes. I did several restarts. Every time I got the tuner LOCK successfully. Further I checked the SD card with my Windows PC. No complains about fixing for errors.
Success:
When HDStar tuner attached with LOCK state, WiFi hotplug works and not affected with the tuner LOCK
Failure:
WiFi hotspot gets disabled when HDStar tuner is hotplugged and also unpluuged (sometimes) from the Pi
Do you have HDMI out? If so, can you watch that while plugging in the tuner and tell me if you see a bunch of i2c-related errors pass by when you plug it in?
So now I’m not sure what’s going on anymore. Iirc, the original problem was that you’d loose wifi connectivity when HDstar is plugged in. Is that still the case?
Yeah, I’m not 100% sure what that means. I know that it’s not a good thing before it boots. Once it’s booted, though, I haven’t noticed anythig wong happening when green LED is permanently on.
