I have dish pointed at Galaxy 19 and receive video on my skybox F3. I remove the Skybox and set up light house and can not connect. I have tried both KU lnb settings and changeing TP frequency a little up and down. I am in up state NY.
version 0.4.post4 Lighthouse 1.3.000
I tried to upload logs to this post, but can only upload pictures?
Blind scan option would be nice.
What should I try next?
Still no luck for signal from galaxy 19. My dish is pointed correctly and I can see everything on G19 with my skybox. Can anyone tell from the logs I provided if the lighthouse tuner is functioning? Perhaps I have defective unit?
Now I have noticed that for newer logs, all entries are dated January 2015. The lighthouse is not keeping time when power is removed, and it is not asking for me to set the time or perform setup on power up.
Is there a firmware I can load that would confirm tuner function? Or perhaps provide file and instructions for me to reflash lighthouse to most current code and I try again?
Hello,
Interesting, I have never looked at the radio stations.
Yes
Outernet on galaxy 19
FQ 11937 V SR 22000 SNR 72% varies to SNR 74%
Channel 46 of 81
I am not able to hear any audio program.
Were you able to test the receiver section of the unit, or just the software?
Everything seemed to function, but I could not get any indication of receiving any signal.
Then after the first day, the logs were not showing the correct time and date and I could not
figure out how to update the date and time after the first init.
John
Hello,
Thank you for your support. You have exchanged my original unit. (Which is great!)
Sad to say I still can not get any signal. I am trying to review everything. I am using
a standard lnb, has anyone been able to get a signal out of G19 with a standard
lnb? I have tried both standard and universal settings in the light house software.
There’s no audio, but it shows up as a radio channel.
Our staff in US and Canada all use Galaxy 19 without issues and at least one of them is using NA Ku.
I’ve reviewd the logs you originally posted. I don’t see anything wrong with it except maybe multiple consecutive tuning attempts (which I presume is you). Note that it may take up to 5 munutes before data starts to stream in.
I have not figured out to understand the logs yet.
I noticed that at one point in the logs, the time is set and is reflected in the log’s time stamp.
Would I have had to connect for the time to set? if so, what settings did I have?
I have not seen any signal on the graph, should I wait 5 minutes?
I don’t get it, something simple is hanging me up. I have ordered a new lnb. Mine is
over 10 years old. It is either the lnb or the cable. I will change the lnb and try new cable.
Will update you with results in a few days…
