Hi,
ORxPi2 What is the login and password.
Hi,
Shell or web UI?
Sorry, what is UI?
Librarian UI. One that looks like this.
After I finish installing the card it asks me to log in ( user name ) and a password
Can you describe in more detail step by step of what you did?
ORxPi2- 6 files on SD Card,run to Raspberry Pi2 and install,scan ,finish ,login and password
I copied from ORxPi2 the six files on the sd card
bcm2709-rpi-2-b.dtb
bootcode.bin
config
fixup.dat
start.elf
zImage
Can you give me a screenshot of the login/password step?
I put the card in the Raspberry Pi2
i can do it in ten minutes
Ok, thanks.
That’s the shell. Username and password are both outernet.
The receiver is a web server, though, and the action happens in the Librarian interface. For that, you will need to access it over a network (your LAN router or using a WiFi dongle).
Is your PI connected to a router?
yes with wired
If you type ip addr it will tell you the IP address of the Pi:
On my Pi, it’s under eth0, inet, IP address 192.168.10.215.
Once you find the IP address, access it using a computer/laptop/phone:
http://<IP>/
Success- I received a welcome to outernet
Excellent!
