This hotfix release fixes a critical bug in previous releases that causes loss of data. The issue is present in firmware images since 2.5, and affects users that have attached external storage. When storage is removed and then immediately reattached, files that were on the external storage were physically removed. If you are using the external storage, we recommend you do not remove your external storage device until this hotfix is applied.
Download locations:
Please also find the up-to-date instructions on manually updating your Lighthouse:
