Many thanks for testers. We’ve released firmware 2.2.00 for Lighthouse and ORx.
As mentioned in the summary for the last snapshot, this firmware fixes the following issues:
FSAL not picking up new downloads
Monitoring fixes
Twitter date update glitch
Issues with filemanager when typing in full folder paths into the search bar
Known issues:
It is possible that the tuner settings panel sometimes reports no lock even though the lock is not physically lost. You can tell the difference between this bug and actual no-lock condition by checking the IPC response from ONDD. If ONDD fails to respond to IPC calls, then you are observing this issue. If ONDD’s responses are normal, then you have actually lost the lock. This condition may manifest itself every 5 minutes. We have removed some 12,000 files from World Possible in order to minimize the effects of this bug and are working on a proper fix.
NOTE: Lighthouse should receive the firmware update as part of the downloads. You don’t need to do anything to have it updated. If you can’t wait for the update, you can use the download link and flash manually.
Lighthouse 2.2.000 automatically loaded into my Lighthouse (which was running 2.1.003).
All looks fine - - I am seeing 4 carousels instead of 5, and my Monitoring ID code has changed. I also see the Status page is working fine again. Merry Christmas all you Outerneters. Ken
-the tunner is randomly disconnect and not get new signal look, i must login and presss “update setting” to get new tune or reboot the LH. status page on situation
-i suppose that the LH its no using external sd storage, since 2.2 update the size has no change , but there is downloads ongoing image
-some old bug , i can not delete old content from gui on non supported languages
Just tried it with the same result. The initial access to the web interface after a fresh start (fresh install on an SD card on a Pi2), on the initial boot, resulted in the ‘500’ error. This time all I did was disconnect the lan cable, and plug it back in and it was fine.
After that , I ran through all the initial setup stuff and am receiving files.
It looks like an issue with the first initialization of the LAN interface.
FYI, 500 error page is a misleading pain in the behind that we still haven’t fixed. It only means that the application hasn’t started (yet), and on first boot it may actually take up to sevral minutes. I would advise that you reflash a new card and leave it to boot for a while. If it fails to boot into a completely functional web GUI, then we have a problem.
