I see that if I want to make a DIY receiver I need:
Antenna
Amplified
Tuner
Board Computer
Power Supply
Can anyone fill in the specifications and the bare minimum for each part? For example What Frequencies do the the Antenna and Amplifier need to be able to operate at?
In my humble opinion, the cheapest and easiest way to get started is to BUY the Outernet starter kit.
It works really well, and if you have a problem then every one has the same equipment and can help you.
I have had the Linux setup for a while and then I got Outernet running on the $9 CHIP. Clearly the CHIP is the way to go albeit a bit slow, It does the job.
Once you have Outernet functioning by all means experiment with alternatives.
