In the first photo in the “About Latern” on Indiegogo, it says the Latern has a SMA connector. I find this odd, as almost every LNB on the planet has an F connector. I assume the SMA connector was chosen for it’s size. But, is this really a good idea?
Even if you include a F/SMA pigtail cable, it will get lost. If you use an F connector, almost any Ku satellite dish in the world could be used with the Latern.
cheers,
glenn
