Greetings,
I supported the project, via 3.03.
While I have received it, it has yet to come out of its box. ![]()
I just placed an order for the latest version, and noticed that it doesn’t have an Ethernet port either.
Is there a list of supported USB to Ethernet dongles that will work with the unit’s?
Thanks in advance,
-Chui
most usb-ethernet dongles should work. That said, this is not officially supported.
Hi, Muro
It has been discovered that v3.03 and v3.05 will work with a TP-Link UE300 ethernet adapter. If you check the online user’s manual at:
https://cdn.shopify.com/s/files/1/0770/0935/files/Dreamcatcher_V_3.03_User_Manual.pdf?2374097566012967518
I believe there may be an instruction appendix related to this.
@Abhishek @maxboysdad
Thanks for the replies, and information!
-Chui
