i just tri to update the LH
but now I do not know, if it was a successful update
i get this on uname -a
Linux outernet 3.10.61 #16 SMP PREEMPT Fri Dec 11 20:31:26 CET 2015 armv7l GNU/Linux
i supose this is 20003, but no sure
no web interface, error 500
bash seccion of the log [ 64.762291@1] unionfs: new lower inode mtime (bindex=1, name=site-packages) - Pastebin.com
branko
2
The /etc/version file contains the platform version.
Can you check if librarian process is running at all?
ps ax | grep python
Also if you got that warning from udev, it’s worthwhile to check the system log:
grep hotplug /var/log/syslog
hi
i run ps ax | grep python
and noting show up, so outernet was not runnig
i run cat /etc/version and get 2.0.003
for some reason that i dont understand there was an error on updating the LH
solution
turn off LH
them i remove the sd card whit the data, do not touch noting
and use a new sd to put boot.img and outernet-rx.pkg same version 2.0.003
and make a restore for LH
after the restore LH starts normally, i configure it and them make a reboot
when LH start up again i put the old SD whit all the data, and them LH ask to import the data, i select yes
and just works
there is some strange folders , but i supose its the bad procedure of update
kalasalsa.no-ip.org:88 runnig
tnks for the help
i will try 2.0.004 tomorrow . . … .
branko
4
This is probably related to postgres permissions issue I mentioned in the 004 thread.
