Hi -
I just received my board and got it pointed at the satellite easy-peasy (ty @kenbarbi ). I can watch the on-board display and see that it is operating and the signal is strong with good snr and only occasional loss of lock. The problem is that when I connect and log in to the web ui it freezes up quite quickly. My power adapter is rated at 3.5 amps and works just fine on other, more demanding, projects. I have yet to be able to catch any error messages.
Still no luck, so I I ran this on my desktop to check the cards. Here is a typical result:
sudo hdparm -t /dev/sdf1
/dev/sdf1:
Timing buffered disk reads: 276 MB in 3.00 seconds = 91.86 MB/sec
So, I also tried several browsers on both my MacOS Mojave and on my Linux computers. Chrome and Vivaldi lock up the dreamcatcher immediately on both systems, as does Safari on the Mac. On both systems Firefox will allow me to check the LNB data in the âtunerâ but locks up with any other option. Yoiks!
Definitely seems like a software issue, but a fresh image should have solved that. Iâm happy to send a replacement for you to test. Can you email hello@othernet.is with order details?
