I ordered a Dreamcatcher 2301 and Bullseye LNB today. I am excited for them to arrive. I was trying to read up on it but the available information is scattered around the forum and it is hard to tell what is up to date. Is there a one stop location with all the information that I might have missed?
As far as I can tell I will need to:
Pus a SD card in the holder on the dreamcatcher board. The SD card needs to be no larger than 32GB and formatted FAT32.
Connect the Dreamcatcher to a computer with a USB C cable to update the firmware.
Point the LNB at 87W. (I am located in the 52dBW contour)
Connect the LNB to the dreamcatcher with the dreamcatcher off.
Boot up the dreamcatcher, connect with wifi, enter the satellite information.
Tweak the LNB to improve SNR.
Is a dual or quad version of the bullseye LNB available anywhere? I have a FTA dish pointed at 87W and it would be nice if I could just replace the LNB I have with the bullseye but I want both polarities. Is Othernet on 87W using a horizontal or vertical transponder?
Can the USB port on the Dreamcatcher 2301 be connected to a USB flash drive and content stored on the flash drive so it does not get removed automatically?
Can a USB to ethernet adapter be used with the Dreamcatcher 2301 to connect to my LAN? If so what chips work?
Can both a USB flash drive and an ethernet adapter be connected with a hub?
Thank you,
-Stv
