Hi, I’m currently setting up my installation, and have been offered a 60cm dish. Your DIY instructions say minimum 80cm.
Looking at the hotbird 6 footprint I should be getting 53dBW EIRP at my location and from the table at the link below, I should be OK.
Hi JohnSpace,
I made some months ago a comparison between two parabola dish with different sizes.
I had a chance to use a so called mobile satellite tv receiver dish. It is small, lightweight, with 38 cm diameter, proposed for "camping use’.
I can summarize this small expeiment wihth the conclusion, it is usefull for receive broadcast tv stream, but not enough for receiving outernet files.
Mybe the explanation is simple: if you receive the tv data stream, it is not a problem, if some data packets lost. You can enjoy the tv program, if it has some “lost-pixels” on it.
But if you receive a file, witouth any feedback in the data stream, and if you lost one data packet, you havenot any complette file as a result.
The last consequences is, if you have option to choose larger dish to receive outernet data stream, you can do that.
I regularly use a 90 cm dia parabola, at the position 47.48 and 19.01 (Budapest)
From this position the Hotbird 13E visible on 35 grad elevation.
Just to close this thread out for anyone who finds it, I was able to Rx fine with 60cm dish from South UK on Hotbird 13E. The EIRP figures and dish sizes in the link above are valid IMHO.
