Greetings, I’m a satellite enthusiast from Indonesia I lived in Island of Java and interested on trying on testing the Outernet. What is the coverage status for Indonesia? Which band/satellite should I use?
FYI, at the moment I have 6 feet solid dish installed and well pointed to AsiaSat5, please advise what hardware should I prepare to started with Outernet.
You can always buy the E4000 radio that we have on Amazon. Doing so supports our work and helps to feed the satellite. However, if you are in Indonesia, that is probably not an option.
In that case, I would suggest buying the official RTL-SDR Blog SDR, which uses the R820T2, instead of the Elonics E4000. We’ve heavily tested that radio and it works very well. Any RTL-dongle should do, but the radio must drive an external amplifier and also have a TCXO.
