Ok I hope im not going insane and am completely making a mess of this Topic…
Today i was thinking of building a set up to connect to the Outernet, flicking trough my android phone i turned on an app that requested GPS access… and then I remember my ToughBook has a built in Sat Receiver for GPS and can be Used as a SAT phone if needed…
So then i Taught GPS is using Sats to get location, so the phone must have some sort of satellite receiver with in the phone itself, so could in theory with a small software mod i should be able to connect my android phone straight into Outernet to revive data being trafficked…
Before someone says it dosnt work that way, i did research already, there’s an App called Spot that uses basically connects to a Sat, so you can send an Emergency Text when there’s no Cell Service, call for emergency help and even broadcast your location data, all trough sat without having any phone signal,
So I was thinking is there anyone who is good at programming working on this or am i gonna have to try and learn something to program an Android app that would do this … like it wouldn’t take much, just get the Spot app reverse engineer it and see basically how it connects to there Sat, change out the coding for there sat to the outernet and instead of having other emergency options, change it out to receive files to storage card…
i could even see it one day using the outernet as its out phone network for calls and texts globally… im gonna look into this more… and i also wonder if anyone else is already having the same taughts as me… id really like some input because i can program … im more of a thinker then a coder haha .
