I am really trying to get into APRS here in the Philippines.
I am absolutely delighted that Outernet has agreed to host the back channel for Outnet messages.
Basically a HAM can send a APRS short message addressed to Outnet and it will relay down from Space, on the 3 Outernet Inmarsat Satellites to virtually the entire world. Yep really groovy.
So haw can a Licensed Radio amateur use this Outnet receive option.
Send a APRS message through a VHF radio using a TNC/ Sound-card.
Send a APRS message through a HF Radio using TNC or sound-card. Freq 10.1473 MHz
Send a APRS message to the International Space station or APRS Satgates listening on the Freq 145.825
Send a APRS message through Open-source APRSDroid android software using a VHF or I-gateway. Link to free version of software here APRSdroid - Downloads
There is tonnes of Opensource software Xastir and YAAC are extremely comprehensive.
There is also lots of Open-source sound card software. Soundmodem and Direwolf I have tried and a little bit convoluted to get working but worth it in the end.
I look forward to hearing other people views in this forum.
I sent a message about an hour or so ago. I used the APRSDroid app on my phone. My thinking was that the app is directly connected to the Internet servers and so more likely to get injected into Outernet. If the ground based RF path for APRS is iffy at your location then its also likely that the messages you sent did not get through. It is an amateur network after all.
Youâll know its mine. Look for NI2O as the call and the date in ISO format as the message text.
I guess you could make a APRS transmit only RTL Type dongle but it would be hard to beat Baofeng pricing and you would run into a heap of regulatory requirements in order to sell a transmitter.
The Satellite APRS signal is 145.825.
Amateur Radio equipment on the International Space Station was enabled for APRS digipeating on 145.825 using the path of âVIA ARISSâ.
One thing I am thinking is maybe you can some how use the ISM Industrial frequencies that WIFI etc use.
" The industrial, scientific and medical (ISM) radio bands are radio bands (portions of the radio spectrum) reserved internationally for the use of radio frequency (RF) energy for industrial, scientific and medical purposes other than telecommunications"
Donât forget that youâll also need a modem of some sort for the radio path too. Simply owning a radio does not get you into the APRS network. Youâll need an 1200bd AX.25 compatible modem and some way of speaking to it. These days there are many ways to accomplish this. Software modems, Arduinoâs, PICâs etc.
It demonstrates a cheap way to get onto APRS using the APRSDroid application and $30 VHF ham radio. The modem tones are generated using the sound abilities of the Android phone. Itâll be enough to get into the RF network. Maybe not enough to get into the wired network. APRSDroid can however, inject messages directly to the APRS Internet servers.
Understand that this is an amateur network. It operates by the graces of hams with some spare cash. Nothing is gauranteed. You may send messages and they may or may not get through. The RF network is full of huge hole as can be seen here on my last 4 days driving around NJ, PA and DE aprs.fi - live APRS map Even in the most populated areas the network is very Swiss cheese like.
I would point out again that a ham radio licence is required to access this system.
Whatâs the âppersistâ setting on APRS massages? I sent mine well before midnight last night and they are still showing up on the download 15 hours later.
