I had left my Pi2 running with 2.3 for a couple of days and I see that there is no data i the library yet.
I had seen some files completed in the tuner/download area, as well as the file names changing from time to time, saying 100% downloaded.
I had a look at the logs and did not spot any obvious errors. I power cycled the Pi with no change. I also restarted Librarian and FSAL, with no apparent change.
It appears that ONDD is just skipping everything for some reason. I canât be sure why it does that without knowing all the things you did to your receiver. If your library is currently empty, then itâs probably safe to do a factory reset. SSH into your receiver and do:
sudo facres
EDIT: Please note that this is not an universal fix for all issues. It does wipe your receiver clean of all settings, including SSH host keys, downloaded data, user accounts, etc etc. For a softer approach:
service librarian stop
service fsal stop
service ondd stop
sudo rm -f /mnt/data/cache/*
service ondd start
service fsal start
service librarian start
I have done the same thing - reloaded a fresh image onto the SD card, and it starts up in the same way as before. Just to remind everyone, the Pi starts, but the web server doesnât start right away - I get the error 500.
I then unplug, then plug in the network cable, and the web server seems to be accessible. I go through the normal start up procedures and see that some files seem to be downloading.
Nothing ever gets into the Library.
I am using the Pi2 2.3 image.
Cheers,
Brian
PS: Branko - I can leave the Pi accessible via SSH if you like, so you can have a look around.
Traceback (most recent call last):
File "/usr/bin/bottle.py", line 862, in _handle
return route.call(**args)
File "/usr/lib/python2.7/site-packages/librarian_core/contrib/databases/plugins.py", line 11, in wrapper
return callback(*args, **kwargs)
File "/usr/lib/python2.7/site-packages/librarian_core/contrib/sessions/plugins.py", line 37, in wrapper
File "/usr/lib/python2.7/site-packages/librarian_core/contrib/auth/plugins.py", line 32, in wrapper
File "/usr/lib/python2.7/site-packages/bottle_utils/i18n.py", line 387, in wrapper
File "/usr/bin/bottle.py", line 1729, in wrapper
rv = callback(*a, **ka)
File "/usr/lib/python2.7/site-packages/librarian_setup/plugins.py", line 25, in wrapper
File "/usr/lib/python2.7/site-packages/librarian_captive/plugins.py", line 26, in wrapper
File "/usr/lib/python2.7/site-packages/librarian_setup/routes.py", line 36, in enter_wizard
return request.app.supervisor.exts.setup_wizard()
File "/usr/lib/python2.7/site-packages/librarian_setup/wizard.py", line 39, in __call__
return instance.dispatch()
File "/usr/lib/python2.7/site-packages/librarian_setup/wizard.py", line 61, in dispatch
return self.process_current_step()
File "/usr/lib/python2.7/site-packages/librarian_setup/wizard.py", line 164, in process_current_step
step_result = step['handler']()
File "/usr/lib/python2.7/site-packages/librarian_library/setup.py", line 37, in setup_language
request.app.supervisor.exts.setup.append({'language': lang})
File "/usr/lib/python2.7/site-packages/librarian_setup/setup.py", line 59, in append
with open(self.setup_file, 'w') as s_file:
IOError: [Errno 2] No such file or directory: '/mnt/data/librarian/librarian.json'
The first boot always takes a while, and you get the unfortunate 500 page (black text on white background), while itâs booting. Itâs something weâll make more informative in future.
Thatâs strange.
Yes, that would be great.
Can you post the full diags logs? You can get the logs with the diagnostics command:
Ok, so I finally figured out why there is a no-new-file issue on ORx. It boils down to my being sloppy. Apologies to all of you on ORx. For some reason, the old version of the ONDD init script ended up on the 2.3 image.
So good news is, I know what the problem is. Bad news is, Iâm having networking issue at home, so Iâm not sure when Iâll be able to fix it.
How to copy a file from Raspberry Pi to Windows using PSCP
Assume pscp.exe is located in drive D:
1. Set the path
C:\WINDOWS\system32>set PATH=D:;%PATH%
2. Verify it
C:\WINDOWS\system32>pscp
PuTTY Secure Copy client
Release 0.66
Usage: pscp [options] [user@]host:source target
pscp [options] source [source...] [user@]host:target
pscp [options] -ls [user@]host:filespec
Options:
-V print version information and exit
-pgpfp print PGP key fingerprints and exit
-p preserve file attributes
-q quiet, don't show statistics
-r copy directories recursively
-v show verbose messages
-load sessname Load settings from saved session
-P port connect to specified port
-l user connect with specified username
-pw passw login with specified password
-1 -2 force use of particular SSH protocol version
-4 -6 force use of IPv4 or IPv6
-C enable compression
-i key private key file for user authentication
-noagent disable use of Pageant
-agent enable use of Pageant
-hostkey aa:bb:cc:...
manually specify a host key (may be repeated)
-batch disable all interactive prompts
-unsafe allow server-side wildcards (DANGEROUS)
-sftp force use of SFTP protocol
-scp force use of SCP protocol
I finally loaded up the Pi2 2.3.001 (cant remember how many zeros), and can verify, as others have, that Librarian is back on line and reveiving files. I have seen the same library performance as kenbarbi has reported.
Is there any way to verify that I am one of the devices reporting for Galaxy on the status page?
In general, I think itâs simpler to just check the logs and see if there were transmit errors in the monitoring section. Thatâs a very reliable way to tell if youâre transmitting or not.
