Walk all around your property and try to eye a sweet spot through the trees. Bring your compass. It may not be feasible to put your antenna there. But you never know. I had a similar problem till I moved the antenna a bit.
Just found a signal again and lock , between -9 and -10 on a dish that can normally do a plus 3-4, highest mount so far about 3 foot above the back roof. I don’t know how often the stats update but east Tennessee marker should go green.
Thanks All
Just went to a green balloon
Welcome to the Green Balloon Club !
Noticed the LNA was not aligned with the dish arm, first adjusted the LNA so it was centered , than went searching for the signal and surprise surprise back up to the plus 3 to 5 SNR performance expected, also looks like I found an open spot between the trees.
Very good. Document all the things you did to make it work. That’s my problem. I sometimes forget.
