I think I found a bug! When I try to connect to a satellite, there’s no signal lock and no ‘quality’… HOWEVER, when you try to go into custom and select DVB-S2, you get 0.45 consistent signal quality. Is this Intended? After like 3 hours I’m getting No signal lock…
Here are my specs:
Raspberry Pi B (yes I finally got one!)
The Outernet store tuner,
Wifi access point
A phone
Ethernet (I will post another fix for that workaround on some other thread if someone hasn’t beaten me to it already)
A USB2.0 powered hub
And power cords
Oh and I have an LNB that has 2 Outputs And a really old DISHTV LNB signal splitter…
Sat presets that have this problem ALL OF THEM! (Even the ones that aren’t in green range like the one in asia that (actually) is still in 17 signal range.
*These are all tuned to asia (by accident) but the one that shows the config is really the Eutelsat config.
Pictures:
LNB ‘Dish’ Switch (Back when there were no multi LNB devices, we used these:
Judging by SatBeams data, at your location (that’s near Philly?), you’d need at least 70cm (~27.5") for G19 with a clear view of the sky (not through the trees). For ES113W you’d need 75cm (~29.5"). I would go for at least 80cm if not 90cm and find a better location for the dish.
EDIT: I’ve put together a short guide on how to use SatBeams to determine the dish size.
