I am temporarily using a higher performance software defined receiver, along with SDR-Console application to test my antenna/LNA configuration. (Outernet “branded” patch antenna and LNA)
I see some signals around 1541.5 MHz, some are narrow, others very wide. (I’m in the USA, so I’m tuning +/- 1539.9 MHz)
How much bandwidth does the Outernet signal occupy?
Does anyone per chance have a “snapshot” of what the signal looks like?
It’s a 5 kHz channel. It will be the weakest signal that you see, since the somewhat nearby AERO signals are about 6+ dB higher. I rarely spend time with SDR#, but I can take a snapshot in a few hours, once I get to the office.
