The login in the Librarian does not recognize my password. I am assuming that it is the same ten digit number used here; is that wrong? Please advise.
Additionally, I am questioning my Sat Pointer settings. Usual advice suggests starting at your Latitude for the elevation. my latitude is 32.3118 and the Sat Pointer software say that I should set my el. to 52.4 degrees… That does not seem correct. Any other pointing programs online available?
The elevation sounds correct. If you were at the equator, then you would need to point straight up – 90-degrees. Chicago is at 45-degrees north and I point the antenna with a 45-degree elevation. Receivers in Alaska have a very low elevation.
