@Oliver_Cohen designed a two-part enclosure, which we 3D printed for testing. This is only one part of the two, but it looks great. It slides into the housing and then there is another part (not yet printed) which houses the CHIP and SDR.
I’ll test the antenna inside of the enclosure to see what happens to the SNR.
Cool! As mentioned the antenna coax lead will be the other way around in order that it passes through the male connector of the case into the 2nd part when printed!
