You may need to run Virtualbox as root(on linux) or Administrator (on windows).
If you see a “EIP Value” error in the virtualbox VM window, your computer either does not have hardware virtualization support or the support is disabled in BIOS.
Will the old Weather file be removed from the carousel to “make room” for all these other cool things transmitting more frequently? I’m running the Skylark beta right now but I’ll upgrade to this version tonight when I get home from work.
Ok cool. BTW I read the instructions PDF for v1.0 and I didn’t notice anything about running VirtualBox as an Administrator. When flashing the beta on my Windows 10 machine I needed to run it as an Administrator for it to attach the CHIP to the VM. Before that it saw the CHIP under USB Devices but wouldn’t attach it so the guest OS could see it for flashing.
This may be due to me having the CHIP drivers installed already since I’ve owned a CHIP from the original Kickstarter and have done many things with it previously. Just figured I’d mention it in case anyone else has a similar experience with the flash process not working.
Did a quick eyeball point without trying to optimize. SNR hovering around 5.6, Frame Lock, packets coming in. Hopefully will actually see some whole files soon. So all good from here.
Flashing without problems and the new OS is running.
When i try to change the wifi settings in hot-spot mode, for example wifi channel, the device is not booting.
could you tell me what happens? once you click “save and reboot”, after about 3 seconds, the status led should turn off, and then the boot should happen (takes 25-35 seconds) and then the status led should start blinking.
What part is not happening? oh, and make sure the FEL header was removed.
oh, could you (and everyone who successfully flashes), also include the base OS and Virtualbox version used to flash? That should help narrow down any issues others face.
The status LED turned off and after a while approx. 30 seconds the satus led went on. But the wireless network is not available.
I Used Win10 64b with Virtualbox 5.1.12.
If you change the channel back to default, does the SSID come back?
Yes, mobile support is limited in the UI. it works on the larger tablets, and better on Android than iOS. But overall, mobile/touch support is a work in progress.
