yeah never leave unattended
btw I didnāt had issues with that.
For real āstress testā on drone lipo batteries I use bunch of car headlight bulbs in different configurations thus easily going up 100-150W if needed (free and safe).
Powered my CHIP/LNA/RTL-SDR yesterday on an Astro E5 16750mAh Portable Charger which I purchased a couple of years ago to charge phones and iPads and occasionally running my Raspberry Pis. Starting from a complete charge, it shut down at slightly over 15 hours⦠No power passthrough though.
Tested with 1A resistor load it does 13.8 Ah @5V, calculating back to @3.6V it does 19.1 Ah, 74Wh
What I see that every power bank maker states the ābiggest Ah numberā which corresponding to 3.6V lipo voltageā¦
A bit confusing as everyone looking for the 5V output.
I can confirm that this gizmo does passthrough charging: https://www.amazon.com/dp/B0711NSNQL/ ā itās been running my Dreamcatcher board for a few hours while Iāve shifted plugs, carried the whole thing around the house, inserted a USB ammeter in the upstream line, etc. All perfectly uninterrupted.
Down-side is that it gets pretty hot while eating 5+ watts from the charger, passing ~3 to the dreamcatcher, and storing the rest into the batteries. Hot enough to start melting the plastic case⦠yikes! Note to self, donāt set the thing on top of a blanket next time. It needs airflow!
I like the idea because I can use it as a charger for topping-off my 18650ās from any USB source, or use it as a power bank if I find that I have charged 18650ās and a USB device that needs powering. Bonus, the little LCD shows the current drawn from each USB-A port, though it doesnāt also show how much itās drawing through the micro-B input.
Note that the batteries are not included, so the price is actually pretty terrible unless you consider that a feature. But I figured Iād mention it here since the general style is interesting, and there are versions with varying numbers of battery slots, which might make it applicable to different applications.
cool stuff, but overheating sounds a bit scary as LiPo chemistry is very sensitive for that (dangerouslyā¦)
Zoltan, @zoltan Iām planning to use the Easy acc 20000mAh Portable Charger you recommended with one of my new Dreamcatchers and active antennas. I want to package the receiver in a smaller volume that will be easier to deploy.
My objective is to have a seamless transition from ac power to portable power and back again without a Dreamcatcher reboot. Ken
